B brent21799 Honorable Sep 27, 2013 168 0 10,690 Dec 2, 2013 #1 Is it safe to plug both the 8-pin and 4-pin power into my mobo?
Solution rolli59 Dec 2, 2013 You should only need the 8pin but does not hurt to plug the other one in since the CPU pulls just the power it needs no more no less.
rolli59 Titan Oct 27, 2007 47,790 283 130,890 Dec 2, 2013 #2 You should only need one or the other, normally 8 pin today. If you have an extra 4 pin connector it is only for extreme overclocks, does not hurt anything. Upvote 0 Downvote
B brent21799 Honorable Sep 27, 2013 168 0 10,690 Dec 2, 2013 #3 Well Im using a six-core CPU from intel So should I plug them both in? Upvote 0 Downvote
rolli59 Titan Oct 27, 2007 47,790 283 130,890 Dec 2, 2013 Solution #4 You should only need the 8pin but does not hurt to plug the other one in since the CPU pulls just the power it needs no more no less. Upvote 0 Downvote Solution
