Cpu power problems
ritchyboy
27
My computer shut down when my cpu runs at max processor speed which should be his normal stats I think.My computer will even shut down when he runs at mid power but it will take at least some days but will eventually shut down.Also I had temperature problems before when I build my computer with the former cpu fan(like 6month after building it) but I've solve it by buying my Cpu cooler that I'm mentioning in my specification.
Temperature picture of when I put it at max for 20sec at least: http://puu.sh/g8LOd/5bff1c9ed5.jpg
Cpu power right now to prevent the shut down: http://puu.sh/g8LZm/365755df2c.jpg
Specification:
CPU:AMD FX(tm)-8150 Zambezi Eight-Core Processor
CPU Cooler:Antec Kuhler H2O 620 Liquid Cooling System
GPU: XFX Double D FX-787A-CDFC Radeon HD 7870 GHz Edition 2GB
Storage:Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache
Storage 2:Seagate Barracuda 7200.14 ST3000DM001 3TB
Case:Rosewill CHALLENGER-U3 Black Gaming ATX Mid Tower Computer
Motherboard:GIGABYTE GA-970A-D3 AM3+ AMD 970 + SB950
Memory:G.SKILL Ripjaws X Series 8GB X 1
PSU:FirePower Fatal1ty 750W
OS:Windows 7- 64bit
Hello,
The motherboard you use is not the best match for the processor (it's not officially supported, so at least be sure you use the latest BIOS), but the biggest problem is the CPU temperature: it should not pass over 70 C, no matter what. The voltage is also high; put all settings to default, including BIOS.
Check if the cooler is properly working: the pump should be connected and working, the fans should spinning, etc. Try reseating the waterblock and change the thermal compound.
those high temp on it was on idle or underload and i do not see any fan speed or system voltages this look like you have cooling issue on the cpu the first picture show higher temp ,i would repaste the cpu using mx2 or mx4 and plug the pump in cpu fan header and the fan of it in cpu opt and made shure it is fix correctly on the board and that the pump work and fan spin as it should .
With a lot of struggle since Ive put my bios on default Ihave a lot of problems.I'm either stuck at loading os or my computer does arepair start up and shud down right after I click finish.After that when i do run normally i ablue screen with the only word that I can read so far is hard drive pls help I'm using my wii u to communicate
Check the PSU + CPU voltages in BIOS.
After the CMOS reset, what is the CPU temperature?
Try to deactivate the TURBO function from BIOS. Leave the CPU voltage to AUTO, but reduce the CPU clock (use a lower multiplier value): MB Tweaker --> Core Performance Boost to DISABLE, and CPU Clock Ratio to x15 (it's just an example, x15 will result in 3000MHZ CPU frequency; you can lower the CPU frequency even more).
Try to upgrade the BIOS to its latest version. Be careful though: your motherboard came in multiple revisions: Rev. 1.0/1.1, 1.2, 1.3 (which don't support FX-8150), Rev. 1.4 (supporting the FX-8150 after a BIOS upgrade) and Rev. 3.0 (with FX-8150 support out-of-the-box); be sure you download the proper BIOS (you can find the revision number in the lower left corner of the motherboard, close to the mounting hole).
EDIT: check if the SATA storage is in performance mode (AHCI). On older motherboads, after a CMOS reset, the setting reverts to IDE, which renders the OS unuseable (this could be the reason you cannot properly boot your OS anymore).
thx for the reply i will do that by the ways i just did what you suggest before and the cpu cooler was full of dust so the air of the fan could not pass my cpu temp is around 45C from bios
Only GA-970A-D3 Rev. 1.4 has an F10 BIOS version, and the latest BIOS available is F13b; check again if your motherboard is indeed REV.1.4.
You can upgrade the BIOS by using the Q-Flash utility: download the F12 version (the F13b is BETA version), unzip the file to an USB memory stick (only FAT-formatted USB sticks are supported), connect the stick to the PC, access the Q-Flash menu by pressing the ESC key during the POST (or enter BIOS and press F8) and follow the on-screen instructions.
I just update my bios to f12 (1.4rev) and put my setting like in the previous message still the same blue screen telling me to use chkdsk/f which dont give result like everything that windows has recommend me so far also i dont find my book so i cannot tell the beep code
You are receiving continuous beeps from the motherboard? The beeping continues even in boot stage or only in BIOS / POST?
Please try to post a picture with the blue screen error, or post the error (the error appears in capital letters, and sometimes the name of the file which caused the error is listed below the page, at Technical Information). The BSOD stays on the display or the system is restarting right away? Have you tried to enter Safe Mode (F8 during boot)?
Boot from the Windows installation disk and try to do a Repair or a System Restore. If not, you should consider a fresh Windows install.
Ive brought an hard drive to run a new windows 7 On my computer so now i can run my pc from now how i solve my corrupt hard drive? and thx for the help so far we will get back to the main topic soon :^)
I'm a bit lost where do I find the drive maker software ? to check my hard drive is it that http://puu.sh/ggDoK/fc93df2f4f.jpg(I have to say that my new hard drive even tho it doesn't look like it) my old hard drive (http://puu.sh/g8LOd/5bff1c9ed5.jpg)I cannot access that one in the start up but can go easy as a second hard drive I can even play league from it and run other programs.Also I've play the news dragon ball perfectly fine on my pc cpu temp was around 40-50 barely going to 60 C max temp I got yesterday but didn't stick to it but my gpu temp are higher is it normal? Like 40-80 but more stuck in the 70 C
this for the hdd analyser from seagate http://www.seagate.com/ca/en/support/downloads/item/seatools-win-master/ also on the first picture system tell you that something is wrong with the red x on the flag what it is , you will see your hdd name under hardware the other thing voltage reading look weird use this on the sensor page and report all what it read http://www.hwinfo.com/download.php on ? came to my mind do you have a os on both hdd .
yes I have the os on both hard drive the second one is my main hard drive which I could not enter because of the blue screen I will try what you just link and dont mind the red flag it for setting backup and etc from the first start up
