D doytidalgo Jun 13, 2018 1 0 10 Jun 13, 2018 #1 everytime i play the game.my cpu hot index is up to 80 to 90 degrees..can help me what should i do?
J jay32267 Champion Mar 16, 2017 10,704 1,324 56,940 Jun 13, 2018 #2 You can remove cooler....replace thermal paste....reinstall cooler and MAKE SURE IT'S SNUG. You can inspect your case fans...make sure they are running up to snuff. You can clean filters etc. You can add case fans. You can possibly relocate the machine to a cooler area. etc Upvote 0 Downvote
Z Ztdutxjgxgtu Respectable Nov 30, 2016 632 2 2,160 Jun 13, 2018 #3 Intel cpu? Stock cooler? Intel use very bad quality thermal paste in cpu , causing 20+c increase in temp and comes with tiny weak cooler Upvote 0 Downvote
geofelt Titan Oct 9, 2006 56,056 4,856 174,240 Jun 13, 2018 #4 What is your cpu, cooler, and case? Without that info, nobody can start to give you good suggestions. Upvote 1 Downvote
