[SOLVED] CPU Problem with starting
Jan 11, 2019
15
Soo i was with RYZEN 3 1200, and i changed it to RYZEN 7 2700x. When it was all done i connected everything and tapped the start button of my PC.
It all started as usually, but I dont get any video on my screen, neither my mouse&keyboard are lighting and i thought its not a problem of the CPU...but i can't fix it...Need help sonn pls...Love ya
bignastyid
MERGED QUESTION
Question from shout58 : "CPU Problem with starting"
cookiemania66
Notable
Jul 19, 2018
663
161
Best thing would be if you still have your R3 1200.
Put it back into the Motherboard - it should start without any problems
Then update your Bios, there are good videos on youtube how to do it in your MSI Mobo.
After the Update you can put your R7 back into your System and it should work just fine.
Jan 11, 2019
15
But Do I have to download the BIOS on a flash and then put it (when i put the R7) or i need just to download the BIOS to my PC
MERGED QUESTION
Question from shout58 : "How to start your PC"
Motherboard model name?
You have to update BIOS to latest version before changing cpus.
Jan 11, 2019
15
I was wondering could it work if i ask a friend to download the newest motherboards drivers(idk how they're called) and give me the fpash so i can put it in my PC.Would it work?
