I pulled out a CPU from an old Branded System Unit that is already assembled from the manufacturer. The cpu itself is i5-6400 and I bought a H110M PRO-D and H110 PRO-VD PLUS. Before I pulled out the CPU, the system itself is still working and I just want to add another ram because the other ram slot of the old motherboard is not working.
So tried the i5-6400 with H110M PRO-D and H110 PRO-VD PLUS both of them are not working. There is no display in PRO-VD PLUS but in PRO-D it just keep on restarting...
Does anyone of you knows what's wrong with it? As far as I know 6th gen cpu's are compatible with H110 series motherboards.
I'm suspecting the BIOS of the motherboard. Do I have to downgrade it?
Thanks for your help.
