CPU rear mount corsair H80i and NZXT Kraken G10 w/H80i bottom mount for GPU
Dec 21, 2013
164
Hey guys,
Like it says on the top I was thinking about doing this for my CPU and GPU. The CPU will be a intel i5-4670k and my GPU is a MSI twin forza Geforce GTX 770. Obviously I was thinking about replacing my MSI twin forza with a NZXT Kraken G10 w/H80i bottom mount. (Is this a good idea for the GPU)? So my main question is...
What would be the best fan mount positions for my case fans in the sense of exhaust and intake? This is my case http://www.newegg.com/Product/Product.aspx?Item=N82E16811133201
It has
1x200mm front fan
1x200mm top fan
1x200mm side fan
1x120mm rear fan
1x120mm bottom fan
(quick edit: I wouldn't mind replacing the GPU watercooler with the kraken g10 with a better 120mm rad+fan if you guys have ideas)
As the H80i is not a asetek based cooler it is likely not compatible with the kraken G10 although the corsair h75, h55, corsair kraken coolers and other asetek based ones are compatible. H75 would be best bet if looking for a cooler with good stock fans.
