Hi guys , first time posting so sorry if format or contents are not correct !
So I just received my build , a i7 8700 3,2 ghz , gigabyte Z370 aorus gaming k3 , 16gb ram , Corsair TX750M PSU and a gtx 1060 6gb and a cooler from hyper .
I installed everything and when I went to awaken the beast , it lit up and then shut down after around 5 to 10 secs , turned back on and repeated this until I unplugged it . I then went to check the motherboard and it turns out that the CPU red light is on ( the one with « errors » such as DRAM CPU and system etc ... and I’m not 100% sure what’s the problem ! I’ve tried to swap ram and power supply and no luck there , tomorrow I’ll try another cpu and see where that goes .
So here’s my question , what do I do ? 🙁
And another question is :
My mother board and PSU 8 pins for cpu are different ex : on the PSU’s pins it goes square « house » « house » square and bottom 4 « house » square square « house » and on motherboard it’s not the same , is that the problem maybe?
Thanks and sorry again if not formatted nor in the right area!
X- post from my Reddit on r/buildapc and some one said I am mixing pci and cpu câble but to clarify , the psu cable has cpu written on it!
