Question CPU red light on
Apr 20, 2023
Good evening,
I just finished building my TOTALLY NEW pc. When i turn it on everything looks good (fans, lights, RAM, GPU,..) but a CPU red light on the motherboard is on and the PC after 6-7 seconds shuts down and turns on again and continuously loop.
Nothing goes on the monitor (no signal)
I tried everything RAM replacements, unplug and plug again CPU wires in the motherboard, tried removing the thermal paste and putting it on again.
And still the same problem. Is it the CPU defective or the motherboard?
Thanks in advance
Good evening,
Thanks in advance
We need your parts list. It's possible you have wrong BIOS.
Reactions: ahmaddaoud
Sure,
•MSI PRO Z690-A WIFI DDR4
•Cpu Intel Core i7 12700F 2.1GHz 25MB 1700 Box
•nvidia Asus TUF-RTX3060-O12G-V2-GAMING 12G GDDR6
•Kingston FURY Beast RGB 16GB (2x8GB) 3200MHz DDR4 CL16
•Corsair RM750x 80 PLUS
I just tried BIOS latest version 7D25v1B and still the same.
I noticed that there was a specific BIOS 7D25v11 i also tried it but nothing happened.
Thank you
At this point, confirm the CPU is properly installed. Remove it and check for bent or damaged pins in the motherboard.
I confirm I installed it carefully and in a proper way. I checked but looks perfectly fine both the CPU and the motherboard .
