C Chkerz73 Prominent Jul 9, 2017 1 0 510 Jul 9, 2017 #1 Tried everything to resolve the red light and have narrowed it down to be the motherboard, psu, or the cpu itself. Tried breadboarding and clearing/updating the bios and nothing has worked.
Solution Aeacus Jul 9, 2017 On your MoBo, if the red light is lit by the CPU wording then check if you have any bent CPU socket pins. Though, the CPU chip itself may also be bad.
Aeacus Titan Mar 21, 2015 14,094 2,592 84,890 Jul 9, 2017 Solution #2 On your MoBo, if the red light is lit by the CPU wording then check if you have any bent CPU socket pins. Though, the CPU chip itself may also be bad. Upvote 0 Downvote Solution
