M Matt Polak Reputable Feb 14, 2015 8 0 4,510 Feb 25, 2015 #1 I am planning on switching out my CPU in my PC and was wondering if I do switch out my CPU will it delete any of the data on my PC or can I just replace it without worrying.
Solution USAFRet Feb 25, 2015 Matt Polak : USAFRet : No, it won't delete any of your data, but..... Changing from what, to what? A reinstall of the OS may be necessary, depending on what you are actually wanting. im changing out my Intel Core i5-4570 3.2GHz Quad-Core Processor for a Intel Core i7-4770K 3.5GHz Quad-Core Processor You should be fine. But be prepared for the worst.
zarugal Reputable Jun 30, 2014 576 1 5,160 Feb 25, 2015 #2 No data is stored on the CPU. As long as it's the same socket model it's as simple as swapping the two over Upvote 0 Downvote
rockie_ Splendid Sep 20, 2014 6,022 0 27,960 Feb 25, 2015 #3 No worries ! The data are on storage as hdd and ssd . System data in BIOS Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 178,475 21,373 184,590 Feb 25, 2015 #4 No, it won't delete any of your data, but..... Changing from what, to what? A reinstall of the OS may be necessary, depending on what you are actually wanting. Upvote 0 Downvote
M Matt Polak Reputable Feb 14, 2015 8 0 4,510 Feb 25, 2015 #5 USAFRet : No, it won't delete any of your data, but..... Changing from what, to what? A reinstall of the OS may be necessary, depending on what you are actually wanting. im changing out my Intel Core i5-4570 3.2GHz Quad-Core Processor for a Intel Core i7-4770K 3.5GHz Quad-Core Processor Upvote 0 Downvote
rockie_ Splendid Sep 20, 2014 6,022 0 27,960 Feb 25, 2015 #6 Don't worry http://www.sevenforums.com/performance-maintenance/36798-need-re-install-windows-7-when-change-cpu.html Upvote 0 Downvote
zarugal Reputable Jun 30, 2014 576 1 5,160 Feb 25, 2015 #7 Matt Polak : im changing out my Intel Core i5-4570 3.2GHz Quad-Core Processor for a Intel Core i7-4770K 3.5GHz Quad-Core Processor It's the same socket, and same make. Both your hardware and software will be fine. Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 178,475 21,373 184,590 Feb 25, 2015 Solution #8 Matt Polak : USAFRet : No, it won't delete any of your data, but..... Changing from what, to what? A reinstall of the OS may be necessary, depending on what you are actually wanting. im changing out my Intel Core i5-4570 3.2GHz Quad-Core Processor for a Intel Core i7-4770K 3.5GHz Quad-Core Processor You should be fine. But be prepared for the worst. Upvote 0 Downvote Solution
