Guys if you removed the rentention bracket completly the thing holding it under the motherboard will go loose and you will not be able to screw it on.you have to move it back by removing the motherboard completly and placing it back to its original place or if there is a hole on the pc case push it back in place(worked for me)
First time posting on this site.Hope it helps!
