I Inanimate Prominent Aug 4, 2017 3 0 510 Aug 14, 2017 #1 I know this isn't normal, but I need to use my PC, and have no money to buy new stuff like a fan. Please help, what do I do?!? It's showing that it's running 100 celsius
PCMACPC Notable Aug 5, 2017 282 0 960 Aug 14, 2017 #2 Probably that's fake. Try some other programs: - Realtemp - HWmonitor - Core temp - Speedfan Upvote 0 Downvote
Unolocogringo Illustrious Dec 31, 2007 8,017 806 38,390 Aug 14, 2017 #3 Probably needs cleaning or the cpu cooler is loose. Take the side off and have a look. Intel push pin coolers are known for this problem. Upvote 0 Downvote
PCMACPC Notable Aug 5, 2017 282 0 960 Aug 14, 2017 #4 Unolocogringo : Probably needs cleaning or the cpu cooler is loose. Take the side off and have a look. Intel push pin coolers are known for this problem. If your cpu is running exactly 100c, it's mostly a software issue. Upvote 0 Downvote
I Inanimate Prominent Aug 4, 2017 3 0 510 Aug 15, 2017 #5 PCMACPC : Probably that's fake. Try some other programs: - Realtemp - HWmonitor - Core temp - Speedfan Tried all of those. They all said the same. Running at 100c Upvote 0 Downvote
PCMACPC Notable Aug 5, 2017 282 0 960 Aug 15, 2017 #6 - Did you do some base clock overclocking? - Check temperature in Bios. Upvote 0 Downvote
