CPU running at 50c IDLE help!
jeremy_duck
Commendable
Feb 10, 2017
Hello, I have a pretty big problem and i believe not a cheap fix i've been having a CPU overheating problem for a good week now my pc would start freezing and lagging in rainbow six siege, and after a few mins completely frozen so I would turn off my pc then it would start and say CPU TEMP ERROR i would press F1 and it would say my CPU is on 183F temp but my gpu is running at 30 idle and 50-60max load but my CPU is running at 45 idle and alot on load. my fans are currently on max speed and as writing this post still at 45C on 1 screen at 60hz. so i was thinking i should get a new cpu that will make games look better and i will be able to not worry about overheating while playing at 144hz in Rainbow Six but I don't know what to get.
TL;DR id like to know what i can do to fix my cpu overheating for a little bit and what cpu i should look into to get that will work nicely with my specs and 144hz monitor max price 550$ Thanks in advance.
PC SPECS
GTX 970
i5 4690 CPU
SabertoothZ87 Motherboard
16gb of ram
850 power supply
144hz benq monitor
and 60hz samsung monitor
A good cheap cpu cooler that i think most would recommend for this is a Hyper 212 EVO for a start, but before how long have you had that cpu cooler on the pc because all you might need to do is reapply thermal paste, and that could solve your problem.
I've reapplied thermal paste 2 days ago and for a cpu fan anything under 100 im good with.
