Question CPU Running at max clock speed without even using it?
Sep 15, 2019
4
My CPU is literally using the max clock speed without even using it. Does anybody know what is wrong with it? Here are my specs if you are wondering.
Ryzen 5 2600 (Non-OC, Stock Cooler)
ASUS B450-F STRIX Mobo
Corsair Vengeance RGB Pro RAM 16GB @ 3000Mhz
Sapphire RX 580 8GB
EVGA SuperNOVA 750 P2
Does anybody else have this problem? If so, what did you do to fix it?
PC Tailor
Dignified
Herald
Welcome to the forums my friend!
Looks normal to me, the max clock speed is 3.9 on one core.
The speed will fluctuate and certain cores may boost depending on what you are running and any background applications.
