Question CPU running below base clock speed
Jul 10, 2024
14
Hi,
Wondering if someone can assist me with this..
The base clock speed for my Ryzen 9 5900x is 3.70GHz but under-load for some reason my speed only reaches 3.60GHz.
Now I also noticed this only happens if my PC power setting is set to "balanced" rather than "high performance"; when I change my power setting to be "high performance" my CPU clocks at 4.50GHz-4.60GHz
Is there something I'm doing wrong here? Should I just be on "high performance" the entire time? - My temps hit 90C sometimes if I stick to high performance so I'd rather stick to balanced if possible.
PBO and CBO are both enabled in BIOS and set to "auto"(this is default)
I will provide screenshots if needed.
Edit:
Windows 11 Pro
Gigabyte X570 Aorus Elite
BIOS version F39
Ryzen 9 5900x
ASUS ROG Strix GeForce RTX 3090 DirectX 12 ROG-STRIX-RTX3090-O24G-GAMING 24GB
64 GB G.Skill Trident Z Neo
1200 watt 80 plus corsair PSU (purchased in 2021)
Samsung m.2 980 1 TB (OS)
Samsung 850 evo 250GB (gaming)
Samsung 860 evo 1 TB (gaming)
Thanks,
Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
hi, edited my post to include above.
thanks
