Hello Everyone
I've got a weird problem. I have just built two PCs with the following specs:
PC1
Intel Core 2 Duo E6600 (2.4ghz, Conroe)
Stock Intel Heatsink/Fan combo that comes with the processor
GIGABYTE GA-965P-DQ6
NZXT Adamas Case with stock fans (1 x 120mm rear fan, 1 x 120mm front fan, 2 x 120mm side fan)
Coolmax CUG-700B 700W Power Supply
PC2
Intel Pentium D 805 2.66GHz (Smithfield)
Aerocool Xfire heatsink/fan combo
GIGABYTE GA-8I945GZME-RH
FSP Group (Fortron Source) ZEN FSP300-60GNF-R 300W Fanless Power Supply
When I power up PC1, the CPU quickly overheats and the computer shuts itself off. When I go into the BIOS and check the PC-health, I see the CPU temperature rise quickly from around 60 C to 100 C. When it reaches 100C the computer powers off - this takes about a minute. All the case fans appear to be running, as well as the CPU fan.
With PC2, the CPU hangs around a temperature of 85C, which is still very hot, but not hot enough to power off the computer.
I have not overclocked either of these computers. This is very puzzling to me since I am not putting the CPUs under heavy load, and I would think that my cooling, although nothing special or fantastic, should be adequate for these non-overclocked computers.
Am I simply not using powerful enough heatsink/fan combos? Or could there be another problem. If the solution is that I need a more powerful heatsink/fan, any recommendations for reasonably priced ones would be greatly appreciated. I do not intend to overclock either of these computers.
Thanks a lot!
PC1
PC2
Thanks a lot!
