Hi all,
Specs:
Asus Maximus VI Hero C2 Motherboard
8GB ram.
Intel Core i7 i7-4790K CPU (Quad Core 4GHz, Socket H3 LGA-1150)
- Just installed the Cooler Master RR-212E-16PK-R1 Hyper 212 Evo. I thought the heatsink/ stock CPU fan might be the issue so installed a new one and it's running cooler but still crashing. Fan and thermal paste installed correctly.
Samsung SAM 850 Pro 256GB 2.5 inch SATA III Solid State Drive
WD 2 TB 3.5-inch Internal Hard Drive
Asus Nvidia GeForce GTX 750 Ti Graphics Card (2GB, GDDR5, PCI-Express 3.0)
Windows 10 OS -
Additional info:
2 fans in the case running on turbo.
Bios info shows the same sort of temps 70c+.
Checked CPU temps with Core Temp.
Problem:
I built the computer at the start of this year. It's been running fine but recently has started to crash showing CPU Over Temperature errors. So the main issue seems to be that my CPU keeps getting to 100c and causing the computer to crash when doing things that I would consider to be minimal load - (browsing the internet for a long period of time, but mostly playing Dota 2). As stated above I recently replaced the stock CPU fan and it is running a bit cooler, but it's still crashing which is less that ideal. I double checked that I installed the fan and applied the paste correctly, any ideas as to why my CPU may be overheating?
Thanks in advance.
Luke
Specs:
8GB ram.
Windows 10 OS -
Additional info:
Problem:
Thanks in advance.
Luke
