I have an FX-6100 (3.3GHz) and when idle it get's up from 50°c to 90°c and when it's under load it gets between 85°c to 97°c. This is extremely hot and anytime I try to run a video game (GTA V recently) it will shut it self down from overheating after about 5 to 10 minutes of play. I've go into the bios and have set the CPU fan to run a max at all times but it seems to still struggle and not run at it's max (I've seen it go into the 4200s rpm). The fan I have is an old stock fan and it began to make a buzzing noise and when I looked in through the side panel I saw that it was slowing down quite a bit (into the 400 rpm range). I assume it's both the fan just dying out and i'll probably have to re-apply some thermal paste. Would anyone on here say that i'm correct in think so or could it be something else? Any and all help is welcome
