I have a weird problem.
Story:
More than half a year ago, CPU started to get very hot and I would get BSOD. I realised is the thermal paste is the root of the problem and I've decided to change it. The problem was that I've never changed the thermal paste, so i've followed the instructions on the cover, which were stupid, since they showed you to apply the paste evenly on the CPU. Which i did, only after patching it up and boot to realise the PC was running slow. I've opened the CPU and saw that because of the pressure thermal paste expanded and leaked into the socket. So i started cleaning it , which took a while but after I was done all went smooth, also I've applied the thermal paste correctly this time and all was fine, I had good and cool CPU.
Problem:
A week ago i've booted and notice all went slow again.
But in a very weird way: If I open a new window the animation is slowed, also on movies the frame rate is slowed, all is slowed down.
Yet when I perform a test on CPU it runs at normal frequency. Also it passes any torture test from Prime95 just fine. The voltage and heat seems fine. Also the highest CPU consuming task takes 02% of CPU and there aren't many tasks. I don't think the drivers are the problem since the first screen, the splash screen from motherboard it takes more time to disappear.
Now the weird part: if i open the CPU, take it off the socket and just put it back in, i don't do anything else, when i start the PC it runs fine even for days. And it stays that way. But if i shut it down, and let it closed for a while, when i start the system the problem reappears.
Any solution other that change the hole system, i mean the cpu works perfectly when it doesn't do this problem
Story:
Problem:
