[SOLVED] Cpu running really hot
sniperwolf772
26
Cpu:i76700k
Motherboard: Asus Maximus Vlll hero alpha
GPU: 1080ti
Cooler corsair h150i pro.
My CPU keeps running really hot like 150f-80f while idle I thought it was my cooler not working because I had one before which was the nzxt x72 and it was doing the same thing. But now I got a new one and it's doing the same thing. I am only 14 and this is my first build I really need some help
https://gyazo.com/605f5e20b48269b9b097efdd6a3a62b7
Sniperwolf. You're temps are okay. 80fahrenheit is about 26 Celsius. CPU temps are commonly read using Celsius. You should be concerned if your temps were at like 80C which is 185F. But yours are not. Your temps are good.
