Hey guys
Im having a problem that i don't seem to be able to find an answer to.
(Sorry for semi bad english, not my primary language)
I built my pc for about 2 years ago, and it have brn running great, until this problem occurred.
My specs:
Intel core i7-4790k
Cooler Master Seidon 120V
Cooler Master cm Storm Stryker
Corsair RM650 Gold
Kingston HyperC Fury DDR3 - 16GB
Msi Geforce GTX 980
MSI Z97 GAMING 5
This monday my pc suddenly turned of when i pressed restart.
I turned it back on, and after a minute or two it shut down again.
I was wondering what the problem could be.
I then turned it on and watched my motherboard, it showed that the temperture was at 99C.
Of course i turned it off again
I then proceeded to clean out my pc with caned air, all the fans, also the fan for my cpu cooler.
When i was done i turned it on again and went into the Bios.
The temperture then started at 60C, but quickky raised to 99C again - just running the Bios.
I then searceh around the net, and found out that perhaps i should try to replace the thermal paste.
So i took of my cpu cooler, cleaned it, and the processer too, and then reapplied Arctic silver 5 thermalpaste, using the "x-method", that i had read should be the best method.
But it is still running carzy hot!
What wonders me the most is that the first temperature it displays is around 55-60C, it is deffently not that hot in here.
Do you have any suggestions on what might be the problem?
My specs:
Intel core i7-4790k
Corsair RM650 Gold
Msi Geforce GTX 980
MSI Z97 GAMING 5
