heres my build: https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=254807&action=wish_lists
ok so my computer is about 5 days old and has water-cooling (2 running as exhaust and another bigger fan 20cm fan on top of that radiator outside the case as an exhaust too). so the water cooling should be nice and cool. BUT according to 3 programs (Speedfan, open hardware monitor and core temp) the cpu core is running at 14.5 -18 degrees (while idle) yet "temperature #1" is running at 101.5 degrees (idle) and when i stress test it, cpu goes to 50 degrees and temperature goes to 150 degrees. so if it was the cpu running at 150 degrees then it shouldve melted indefinitely along with anything around it. I've got a 20 cm fan on front and 2 x 10cm fans on the side and 1 on the back. so theres plenty of cooling. so is the "temperature 1" a faulty censor or something?
http://i57.tinypic.com/2evssw5.png
the speed fan application only has categories, e.g cpu, gpu, hdd's etc etc. and it says cpu 101.5 degrees or whatever it is at the time. so im assuming its a censor around/near/on the cpu
