[SOLVED] Cpu selection problem
Nov 21, 2018
Hello guyz my motherboard is Gigabyte Z170X gaming and i am considering buying a new processor that costs about 200-250€ do you got any suggestions? I prefer mostly AMD
Thanks in advance
That’s an intel mobo so AMD is out of the question. Without a bios update, the fastest cpu it supports in an i7-6700k. If it has the right bios, will support 7700k. But both are outside your budget unless you buy used.
