If you are using a graphics card in the FM2+ board then you should buy the Athlon 860K . Its the same processor as the 7850K7870K but with no onboard graphics
These two are the latest most powerful series pf chips for FM2+
The A10-6800K is a 4.1GHz part. If you are using a discrete GPU, that's the highest clock you'll get but it's 32nm so you may be able to overclock a 28nm chip higher.
The A10-7870K is a 3.9GHz part, and is 28nm so it should either overclock better or run cooler. It is the same as the 7850K but 200MHz faster.
