So, a week ago my PC suddenly shut off, no crash, no shutdown, just a sudden loss of power. Obviously I was concerned but after a quick inspection of all the cables everything seemed fine and when I booted back up everything ran as normal. Thought nothing of it until it happened again, and again. Now I have a proper issue.
My CPU is no longer running at expected speeds given the load. It's a Ryzen 5800X, base speed 3.80 GHz. Today I've tried running several different games and am currently running an AIDA64 stress test on the CPU and it's sitting at ~0.53 GHz. This is obviously a problem, I suspect it's an issue with the motherboard possibly caused by an issue with the power supply? However, the power supply is new, recently replaced the old PSU after it up and died out of the blue after only about a year of service. So is my motherboard a problem, or is this something else and I'm off the mark?
Edit: I should mention, it's not a thermal issue, cooler is working fine and temps are at a reasonable if not high 85 - 90°C which is within the chips limits, this system is built in the NZXT H1 case which is a bit of a hot box.
Also here's the full specs.
CPU: AMD Ryzen 7 5800X
GPU: NVIDIA GeForce TX 3070
MoBo: ASRock X570 Phantom Gaming-ITX/TB3 (BIOS v. P2.71)
RAM: G.Skill F4-300 C16-16GTZR DDR4
PSU: Corsair SF750
(Edit 2: Added PSU and MoBo BIOS version.)
PSU: Corsair SF750
