Hey! I recently bought a new Dell Inspiron 15 7000 series laptop to use for gaming purposes. I'm fairly (REALLY) new to the PC scene, but i do know a few things. Anyway, while trying to max out my laptop as best i could (Performance wise) without overclocking or doing anything to void warranty, I noticed that my CPU speed wasn't going as fast as it was when i first bought it. My CPU should Turbo-boost up to 3.5GHz, and when i first bought it, it was getting up to 3.10-3.20 GHz on the "High Performance" battery setting, with visuals better set to prefer performance and anything else I could change within my laptops settings without overclocking it in order to squeeze every last drop of power i could get. However, now it just seems to cap out at only 3.08 GHz. The only time it ever fluctuates is if I unplug the charger, change the battery/power options, or change the amount of cores it's able to use (It's Quad-Core), but even then it's only caps out at 3.08GHz. I already contacted Dell and they said it was "up to the computer to decide", however, that doesn't make any sense since the CPU used to be faster than 3.08GHz. It already has every new update installed and has Windows 10 Home.
Any Tips? 🙁
Any Tips? 🙁
