Q9450 Core 2 Quad
Asus P5E Deluxe Motherboard
Thermaltake VA8000B Series Full Tower (This thing is good at thermal control)
(CPU has the stock heat sink on it for the time being. Waiting on next paycheck to replace it.)
Okay. I am new to overclocking so I entered my bios with a very careful plan of attack.
THE PLAN===>
Use a USB Flash drive to make a backup of all bios settings.
LOOK over all the settings very carefully
Use that information to "PLAN" a future overclock...
I made my backup of the bios settings on my keychain flash drive. Then I verified that I could restore that backup okay.
After I restored the settings to the bios, I booted windows.
For some reason, my CPU was then running at 2.0 GHz instead of it's stock 2.67GHz... After investigating I found that my CPU was running at 333.3MHz X 6. (333.3*6=2000MHz)
Somehow, going into bios and making a backup of the settings... And then restoring those same settings... Changed my CPU clock speed.
To make a long story short... I changed the multiplier from 6 to 8 (Where it's supposed to be) and now my machine is back at it's stock 2.67 GHz CPU speed.
HOWEVER, it now seems to be running hot... 60C - 71C depending on load.
What gives?
- Witt
PS - Going to submit this forum thread, then shut down my PC and open the case... I am going to verify that my heat sink is still seated correctly.
THE PLAN===>
What gives?
- Witt
