CPU swap shows VGA error LED on both PCs (6th gen and 7th gen swap)
Jun 24, 2018
6
Hello, I was swapping CPU's between PCs
(bazooka b150m, i7 6700k stock, 2x4 gb ddr4 2400, GTX 1070, 600 watt PSU, 250gb SSD, 2 TB hard drive)
(bakkoka b250m, i5 7400 stock, 2x8 gb ddr4 2400, RX 580 4gb, 600 watt PSU, 500gb SSD, 1tb hard drive)
I updated both motherboards to the latest BIOS and swapped the CPUs and when I turned them on they both beeped and the VGA LED was on for a couple seconds then they shut off. It was the same for both PCs and when I swapped them back to their original PC they worked just fine. I know that both GPUs are working just fine.
What could be the cause of this?
You may need to reset the CMOS on both motherboards after swapping the CPUs.
Some motherboards don't like dramatic hardware changes without a CMOS reset.
Thanks for the reply,
Do I really need to reset CMOS if I never even modified anything in the BIOS? Could it be because both of the PCs are pre builts from Cyberpowerpc?
