A action_gamer Distinguished Feb 6, 2010 6 0 18,510 Mar 11, 2010 #1 hi buddies i have some C2Q 9650 3.00 GHz in normal activity i got some temp about 40-50 and in loading e.g when im paying battle field bad comapny 2 my temp is around 70-73 is there anything wrong?or its normal?
Solution D D darkreborn Mar 11, 2010 Try cleaning your heat sink, there might be some dust inside the fan or just get new thermal compound or air spray w/e its called.
LePhuronn Distinguished Apr 20, 2007 1,950 0 19,960 Mar 11, 2010 #2 sounds a little high if you're not overclocking, but not problem high. what's your cooler? Upvote 0 Downvote
D darkreborn Distinguished Dec 8, 2007 31 0 18,540 Mar 11, 2010 Solution #3 Try cleaning your heat sink, there might be some dust inside the fan or just get new thermal compound or air spray w/e its called. Upvote 0 Downvote Solution
A action_gamer Distinguished Feb 6, 2010 6 0 18,510 Mar 12, 2010 #4 yeah solved heatsink and silicone peoblem i fix it and i have 50-53 in load mode and now my cpu temp is around 30-40 sometimes got 25 *C. thanx all Upvote 0 Downvote
A action_gamer Distinguished Feb 6, 2010 6 0 18,510 Mar 12, 2010 #5 Best answer selected by action_gamer. Upvote 0 Downvote
