A ahmedyahia7032 Jun 15, 2018 1 0 10 Jun 15, 2018 #1 I have an Intel I3 cpu 4130 4th gen. The temp on idle mode is 35 c. I wonder if it is okay or should I worry?
PuperHacker Distinguished Jun 25, 2016 992 12 19,915 Jun 15, 2018 #2 My i7 4790k is sitting at 42 idle with watercooling. You should be jsut fine, as what matters is mostly max temps. Upvote 0 Downvote
geofelt Titan Oct 9, 2006 55,781 4,720 174,240 Jun 15, 2018 #3 You are good. At idle, I look to see 10-15c. over ambient. 35c. is a good indication that you have mounted the stock cooler well. Upvote 0 Downvote
