So I have a i7-9700 (not k) that came with a stock intel cooler. I changed the cooler because I wanted to try something new. Turns out, the new cooler I bought was way loader than the stock cooler. So, seeing as how I never had a problem with the stock Intel cooler, I decided to switch back to it. I cleaned all the thermal paste on the CPU and the Intel cooler and re-applied some new paste I got from Amazon and re-seated the cooler. Everything seems good and the temps I got were around 30-40C at idle on the desktop.
So then I run Prime95 for exactly 1 hour and stress-test all 8 cores on the CPU. I come back, turn off the stress test and look at my CPU temps. and they were... 42-45C after an hour of the stress test with the fan and CPU at 100% load. I know it sounds strange but this kind of concerned me with it being so low. I thought the CPU would be at least 80-85C but maybe I'm mistaken. I used MSI Afterburner, SpeedFan, and then checked the CPU temp in BIOS right after the stress test. They all basically gave me the same temp . range: 41-45C.
Should I be concerned about a faulty reading or are these low temps possible? (This is the new thermal paste: https://www.amazon.com/dp/B011F7W3LU?ref=ppx_yo2_dt_b_product_details&th=1 . If that is what's keeping things cool, boy do I recommend it.)
