Question CPU Temp high, Fans running at high RPM
Nov 15, 2020
Hi All,
I've noticed a bit of a dip in game performance (for any games that require CPU such as Siege 100%, Any MMO 70-80 % etc.) I will play for a couple of hours, close the game and my fans will still be going crazy at CPU temps of 50-60c. Even idling I can hear my CPU fan is quite loud. I find that once my CPU temp is up/I have used it for something intensive my fans stay loud until I leave the PC off for a while.
So far I've done the following:
  • Updated my BIOs
  • Clean install of windows (and subsequent full system scan with malwarebytes)
  • Cleaned PC and CPU fans of all dust
  • Changed Thermal Compound on CPU
  • Tested my HDD/SSD with the windows Disk Check utility (says they are fine)
I will take any suggestions at this point, I'm extremely confused.
Specs:
  • i7-7700k / 4.20GHz
  • Corsair Hydro H100i Cooler
  • 32 GB RAM
  • NVIDIA GeForce GTX 1080 Ti
Prad_Bitt
Notable
Jul 4, 2020
1,098
245
1,140
39
Hi All,
  • Updated my BIOs
Specs:
  • 32 GB RAM
Well the CPU itself is old, and probably with updates those games are pushing more than that 7700K can handle. After high Temps, it does take a while for the CPU to stabilize at usual idle instead of idling high, that's true for even me, so I don't see a problem
Nov 15, 2020
I'm saddened to hear that my 3 year old CPU is in the realm of old- I was hoping to push another year or so out of it :(
I'll still take other suggestions! :)
Prad_Bitt
Notable
Jul 4, 2020
1,098
245
1,140
39
LOL, tech is changing pretty quick, your CPU is now equal to an i5-10400F, which retails at half of the 7700K at release where I live :D. Flagships become mid range in a couple years now.
I would definitely recommend pushing it for another year, because Intel is due to bring 10nm next year (lol we hope)
