hi all,
i recently installed cpuid hw monitor when i noticed that one day my cpu fan was way too loud, since then im worried about my cpus temps. its a fairly new x4 750k with its stock cooler; now the problem is that the temps in hw monitor and the temps in my bios software for windows are radically different. in my bios software its circa 55 degrees celsius at full load whilst the "cpu package" temp , the only one in hw monitor, peaks at 84 degrees which is abnormal and even critical. the question is which one is the correct one and should i be worried? also i should mention that under temperatures under mobo are the same as the ones in the bios software, those temps are right below the cpus fan measuring in the mobo section. thanks in advance ppl
