CPU temp issue
Iervolino
11
I ran prime95 for a temp check and my cpu was hitting ~90°C when using the small FFT test.
As the temperature was high I cleaned my cpu cooler (zalman cnps10x) and changed thermal paste. The thermal paste I have is 7-8 years old and I think its probably dried out but I used it anyway.
Running the prime95 test again with the same settings (small fft) I got 61°C max temp and I thought my issue was solved but the problem is, after an hour of using my pc, I ran the same test again and the temp was hitting 90°C once again...
Do you think the issue is the thermal paste?
Most likely thermal paste, all paste has shelf life and I'm pretty sure 7-8 years is quite a bit more than most paste shelf life. For example Noctua NH-T1 has a recommended shelf life (in tube) of two years and in use of three years.
