hello, first of all sorry for my crappy english.
i recently bought an asus tuf z270 mark1 (was able to get it for 150usd) as a
replace for my older msi b150 gaming m3. i'm running a 6700k @ stock, no OC
(planning to upgrade to the 7700k in the future since i don't have the money to buy
a whole new 8th gen system), on a corsair h100i gtx. when i had the b150 chipset +
6700k, my cpu temps never went over 68 degrees under heavy load (i render a lot),
but now with the new z270 chipset, my cpu temps are as high as 88 degrees.
i reapplied thermal paste twice (cleaning the first attempt of course), i removed
both chasis side panels for maximum airflow, i ran all fans at full speed (ignoring
the huge noise output) and yet i was getting temps in the high 80s. the z270 mark1
doesn't seem to have any issues so far, everything runs normally, no chrashes, no
reboots o blue screens.
cpu idles @ 30-40 degrees, gpu idles @ 35-40 degrees, other temps fluctuate from 30
to 45, which is pretty normal since in cuba ambient temps go from 25 to 32 degrees.
i check temps with asus thermal radar and aida64. i know a thing or two about PCs but not too much though...
i did no reinstall windows after switching boards, but i will, once i get the latest version of win10, i'm running a 2016 version (internet access in my country is VERY limited, so software support
ain't an option). also, it makes no difference in temps whether i activate in the
bios intel's XMP or not.
my question is, is this temp raise normal? am i doing something wrong? am i missing
anything?
thank you all in advance
my system:
i7 6700k @ stock
corsair h100i gtx
asus tuf z270 mark 1
16gb corsair vengeance led @ 3200
saphire r9 390 8gb
7 generic 120mm cooler master fans @ 1000rpm
1 noctua 40mm fan for the mobo
evga 850p2 psu
2 sata hdd and 1 sata ssd
cheap chinese case with plenty of space inside
anything?
my system:
i7 6700k @ stock
corsair h100i gtx
saphire r9 390 8gb
evga 850p2 psu
