edit ok i am confused now,
Speccy is showing current CPU temp around 90c
whilst MSI command center is showing 49c
and i just downloaded another temp checker and it also says 50c
so speccy is just not reliable
Just decided today to download speccy, i havent checked the stats of my pc in quite a few months(at least 4 months) and today my CPU temp is running between 80-93c. Thats really high(its on idle) and i have no clue why. My current fan speed is fluctuating between 1500-1700rpm. Mobo temp is fine (32c), temps on other parts are fine. No high cpu usage at this moment. >2%
What should i do?
This is my first pc, i built back in october i think it was, the cpu fan it came with already had thermal paste applied. Everything was working fine for several months when i first built this.
amd ryzen 5 cpu
b450 tomahawk mobo
What should i do?
amd ryzen 5 cpu
b450 tomahawk mobo
