I've replaced my old Athlon X2 5200+ with an Athlon II X3 435.
By performing the upgrade, I got to know the CPU temperature sensor in my motherboard (Asus M3A) is broken (it reports higher temps than the actual temps), since I installed my old X2 in a friend's computer and it was like 45º C under load instead of 65º C in my mobo.
So, the Core Temp sensors in the II X3 seem OK, since they get up to 43º C under load at most (CPU Temp is 66º C under load).
I would like to know what my CPU Temp should roughly be according to the Core Temp sensors. Hence, I ask you which are your corresponding CPU and Core temps for your processors (at load, preferably)? I'm afraid the comparison may be only valid with AMD's Phenom II and Athlon II CPUs, but I invite anyone to post their temps.
