If you want to get a good read on the cooler though, first let it sit idle for a few minutes (preferably restart and let it sit a few minutes and watch temps) then do a load test. There are 'burn-in' tests like Prime95 or Intel burn test that put a high load on the CPU as a stress testing mechanism. That sort of test will basically keep the CPU at 100% load for as long as it takes to complete the tests. The first test gives you the floor (you want to see it steady around a low temp) and the stress test will let you see how hot the CPU will get.
No, at idle it shouldn't change that much, hence my concerns above. A difference that large ordinarily indicates the chip is at load, as opposed to idle.
When i used cpuid hwmonitor my pc was running google chrome, some downloads and some software installations
According to you if my pc was at load is that fluctuation normal?
