CPU temperature goes up and down
faris540
Commendable
Sep 7, 2017
7
Hi,
I have 6700k with hyper 212 and I'm noticing that the temperature of the cpu cores aren't stable.
I used Afterburner and Core Temp and the results were close. There are always one or two (rotating) cores with +50C (just using chrome) and the rest almost -30C.
The CPU temperature is 40-55!
While gaming it reaches 65C at most which I think is acceptable (not good but not bad?).
3 days ago, the maximum while gaming was 57C and in idle or using the chrome it was ~30C. I don't know if there is something wrong or it is OK.
Thanks Kasper.
Didn't you think that cpu temperature is a bit high while using chrome?
I checked task manager and only %14 of cpu is used (%13 of it used by windows update even while no update is installing or downloading?)
Also while playing just cause 3 it reaches 65c with hyper evo 212 installed. Isn't a bit high? (I'm new to pc)
Latest posts
