CPU: FX 6300
CPU COOLER: Hyper Evo 212
Motherboard: Biostar TA970
Windows 8.1
Hello,
Just recently, HWMonitor has been giving me inaccurate readings in regards to my CPU temp as well as its power. At idle, it'll go from around 29 C (normal) and then drop all the way down to 17 C. Then, it'll go back up to 29 C and repeat this process infinitely. The power is also jumping from 21.60 W to 30.70, sporadically increasing and decreasing. I use SpeedFan to control all my fans, and I was also getting sporadic readings from it as well. Keep in mind that my readings were completely fine until a few days ago. Here's what I did so far:
-Uninstall and reinstall HWMonitor
-Uninstall Speedfan - perhaps there was a conflict with speedfan sensors and MOBO's sensors?
-Virus scan with AVG, Malware Bytes, Iobit Advanced System Care, CC Cleaner
I'm starting to think that maybe the CPU sensors are starting to malfunction. I find it weird that both the temperature and power readings are going haywire. Will this cause cooling issues from the cpu fan in that it can't get a stable reading? Any help greatly appreciated. Thank you!
Windows 8.1
Hello,
