CPU Temperature Question
That is the socket temperature and not the core.
It is very high though. If your using the stock heatsink and fan that came with the CPU i suggest you change it. They are terrible.
You can try touching the heatsink near the CPU to see how hot it feels. It could be a faulty sensor.
I see you have an AMD APU. Good luck getting an accurate temp of the cores. I have had 3 APUs, and several FX processors. I have yet to find a program that can read the core temps. Not even AMD's own Overdrive reads them. Usually the tmp0 is close to accurate, though. See if your MB disk comes with a utility pgm that can read the temp.
I seriously doubt those temps you show are correct.
