Hello
i'm just starting with my setup.
cpu: intel i7 8700k
Motherboard: asus rog strix z370-f gaming
graphics card: asus rog strix 1070 ti
cpu cooler: corsair H110i gtx
I just bought a new case and yesterday I wanted to change all the components in the new case, I took pictures of the current setup so I was sure I put all the components back correctly.
my problem is that after the switch the cpu reaches 90-100 degrees within a few minutes after startup.
could see via corsair link that the pump for my cpu cooler runs 0 rpm also tried to check if it was running by feeling the tubes and the pump , the fans on the radiator run as they should.
What could be wrong? is the cooling pump dead or is there something else wrong?
it must be said that everything ran fine before I changed case and the only thing I have done is to take the graphics card, cpu cooler, motherboard and cpu cooler off, I let ram and cpu sit on the motherboard.
any ideas to what could be wrong or a way to test if the pump is actually dead?
cpu: intel i7 8700k
