Remco_,
A minor 100 RPM inconsistency in fan speed is not unusual, and isn't anything to be concerned about. A BIOS update at some point might correct the curve issue and fan speed behavior at idle in Windows.
Fortunately, both Core Temp and Real Temp (developed specifically for Intel processors) allow you to calibrate your core temperatures.
In Real Temp, click on "Settings", then click on "Set TJ Max". Change all four settings from "100" to "110", then click "Apply" and "OK".
In Core Temp, click on "Options", then click on "Adjust offsets". Change "Core 0" from "0" to "10". Make sure "Apply to all cores" is checked then click "OK".
This will correct all your Core temperatures by +10C so as to indicate at least 3C above ambient, which is appropriate for your 92mm 4 pipe cooler.
Having seen a number of these Threads, I suspect that Intel may release a microcode update to correct this issue with core temperatures being too low.
Remember that the Digital Thermal Sensors (DTS) in the individual cores aren't always linear from hot to cool, nor are they always equal in range or response. Sensors can be checked by using the "Sensor Test" in Real Temp.
Although Intel's specification for DTS accuracy is +/- 5C across their entire range, deviations between the highest and lowest cores can be as much as 10C. Sensors are typically more accurate at high temperatures for Throttle protection.
Next, I recommend that you test your Core temperatures at 100% workload. Please follow Sections 11, 12 and 13 in my
Intel Temperature Guide -
http://www.tomshardware.com/forum/id-1800828/intel-temperature-guide.html
Let's see what you get.
CT
