[SOLVED] Cpu Temperature with vertical mount GPU
bidoanie
So i have a corsair carbide spec omega and on top i have a corsair h100i. My gpu is a aorus rtx 2070 super. My question is: if i buy a cablemod vertical mount for my GPU are my cpu temps gonna be affected by the warm air from the GPU ?
You should pay attention to the GPU temperature though,I've seen a lot of threads about people suddenly having thermal issues with the GPU after mounting it vertically, problems they did not encounter before installing it that way.
If you have sufficient airflow, it shouldn't present a problem, lots of people don't experience any issues, but it is worth being aware of
Reactions: bidoanie
