CPU temps after overclocking
Ironhell7
Commendable
Jan 6, 2017
15
I have recently OC'd my i5 7600k to 5ghz at 1.36v with my corsair h80i v2. The ambient temperature of my room is 32C (yes, its boiling here in india). I stress tested my cpu using aida 64 for 20 minutes and obtained the following temps:
http://imageshack.com/a/img922/595/CsVnKB.png
Are these temps safe? Also is the constant voltage of 1.36v fine?
Really there wont be much to do for the temps unless you delid the cpu. There is quite a bit of heat that doesn't get dissipated very well due to the thermal paste Intel uses between the CPU chip and the metal lid. Nothing to be to concerned about I would watch temps under whatever the OP does that is intensive like playing a game or whatever this PC will be used for that stresses the CPU as the temps should stay lower than a CPU stress test.
could you mount an intake fan near the expansion bays to blow across the cpu.
What about push/pull.
FSB ratio overclocking may yield better temps.
I am running out of ideas.
