Hello , I have recently completed my build for my pc. I was considering OC'ing the Cpu but my stress tests are running around 95-99 c at 100% loads when cpu is stock. Is there anyone who can possibly give me some insight. I've read through a few other peoples issues and watched some videos on how to get your pcs running as cool as possible.
My build :
Power supply is Silverstone st85F-P 850W ATX plus silver certified
Case is Thermaltake Overseer RX-I Snow Edition
Motherboard MSI Z87-G45 Gaming LGA 1150 Intel
Cpu Intel Core I7-4770K haswell 3.5GHz LGA 1150 84W
Aftermarket CPU COOLER is the Corsair h100i
GPU is MSI GeForce GTX 780 3GB 384-bit OC EDITION
Ram ADATA XPG V2 16GB 2X GB 240-PIN DDR3 2400 (PC3 19200)
And I got windows 8.1 on a 128gb ssd and a 1TB secondary HD
I have purchased 3 additional fans thinking airflow would fix my temps.
I purchased a better 200mm fan which I placed on the front of my case and put the 200mm fan on my side panel as an exhaust since my GPUs fans push air down I figured exhausting it would be best for heat. I replaced the exhaust on the back of my case because the stock fans are kinda weak the new fan shoots air out like a champ I picked up the Cooler master sickle flow 120mm 2000rpm . Although I have added fans to increase airflow attempting to get as much air through and out in the correct directions and having the h100i my cpu temps seem high. Stress testing only for at most 10 minutes before temps on my first core are hitting 99c. Idle temps are roughly 26-32c and if Im running games it will pick up from 35 to 60 depending on the game. (only game so far that put its around the 60-70 degrees is watch dogs on nvidias recommended settings which is basically ultra with anti-aliasing and a few others graphical settings modified.) From what I read online pcs with this aftermarket cooler should run around 70c on a full load and OC'd. Is there anyone who can recommend what I should do , and if you need anything else let me know . Also I use CoreTemp to watch temps. prime95 for stress testing.
My build :
