S syedqaiser Reputable Aug 1, 2014 31 0 4,530 Nov 18, 2014 #1 My fx-6300 @3.5ghz on a stock cooler is idling at 5 degrees Celsius or less. Is this safe? And yes, i live in Canada......
quandao93 Distinguished Nov 6, 2010 746 0 19,160 Nov 18, 2014 #2 Yea try putting your computer in an igloo that might help a bit. Upvote 0 Downvote
rolli59 Titan Oct 27, 2007 47,805 285 130,890 Nov 18, 2014 #3 It is wrong unless your ambient is -10°C! Idle temps will always be about 10-15°C over ambient. Try different program or set offset. Upvote 0 Downvote
S syedqaiser Reputable Aug 1, 2014 31 0 4,530 Nov 18, 2014 #4 rolli59 : It is wrong unless your ambient is -10°C! Idle temps will always be about 10-15°C over ambient. Try different program or set offset. Don't ask why but i like to keep the windows open at home, so it's a bit chilly. By a bit i mean its -25 outside and the windows are open...... Please don't judge. Upvote 0 Downvote
rolli59 Titan Oct 27, 2007 47,805 285 130,890 Nov 18, 2014 #5 I just doubt it is freezing! -5 to -10°C and you will turn into a Popsicle unless dressed for it. All the energy the CPU uses will turn into heat so impossible to be cooler than ambient unless you are using refrigeration as cooling! Upvote 0 Downvote
