Hey guys, I'm really desperate for some help/recommendations here, so any advise would be appreciated. Thanks for taking your time.
Specs with pics:
i7-4790K No OC
H97 Pro7 Mobo
Deepcool Gammax 400
Case is pretty small
View: https://imgur.com/a/jgqwQvO
These are the concrete ones, I will add other ones if you ask. So basically my problem lately is cooling. When I first got this PC from my office, which is second handed, it was ok, temps were 29-31c on idle, maximum of 72 when playing games with case CLOSED. About 1 month ago I've noticed temps rising more and more, to the point where it gets up to 85c during gaming and 34 minimum, but mostly 37 when idling, FAN spins up faster nearly on every task now. I reapplied thermal paste many times differently (pea, line and etc.), attached the cooler as properly as it can be, checked many times, even reinstalled Windows and it's still the same. Now, when I open my case, it actually drops to "before normal" temps. The ones that I had before, with case closed. I've been told that it may be cooler going bad, that heatpipes should be at least warm on load and that's exactly the thing, when I touch the heatpipes when gaming, they are just a bit warm, like just a bit, and only some of them, not all. They never get any hotter than that no matter what I'm doing. Increasing fan RPM doesn't help at all.
So that's what I wanna know, what's the deal here. Is it my case? Is it because of warmer weather? Because I bought this PC in December. Now it's warm outside, so is that it? Or is really my cooler going bad and needs replacing? It wont be a surprise because this PC is second-hand. I just wanna know what is exactly the cause and should I just get a new cooler, which is what I'm planning to do, but before that, I need a clarification.
Again, thanks for taking your time and reading this, I hope someone will help me out.
Specs with pics:
i7-4790K No OC
H97 Pro7 Mobo
Deepcool Gammax 400
