yeah, that's way too high (assuming it's reporting it's temps correctly, though I suspect it's not reporting temps correctly. first try updating your bios to see if the temps are reported correctly, then try RyzenMaster software to see if different temps are reported.)
ASSUMING its not a software glitch, it looks like the cpu cooler isn't secured properly (or the fan died on it) Pop off the side of the case and visually inspect the CPU fan, see if it's running. Next lick your finger and touch the heatsink attached to the cpu cooler. If there is a bad connection with the cpu it should be warm/close to room temp, if it's connected properly with the cpu, those heatsink fins will be hot enough to boil water (which is why you lick your...
