Get a better cooler?i want lower temps so what could i do?
i will do anything bro liquid metal Delidding etc just name itGet a better cooler?
Decide you are going to worry less about temperatures?
Get a different case with better airflow?
You don't provide many details, so we can't help much with what you have said.
First try with pump and fan at full speed. 70c is not too high but should try to keep up to 60c for best automatic boost. It also may help to have radiator at front as intake, hoses at bottom of radiator and matching fan(s) as exhaust in the case.R5 3600X
120mm Cooler Master Lite aio
temps with 1.12v are at 70c when playing for long time i want lower temps so what could i do?
I have it already set up like this.First try with pump and fan at full speed. 70c is not too high but should try to keep up to 60c for best automatic boost. It also may help to have radiator at front as intake, hoses at bottom of radiator and matching fan(s) as exhaust in the case.
